Specification tree moves. Bug or functionality?
In Catia V5R13 if I put my cursor finger in the specification tree on any of the horizonal branch lines and left click, the model dims and I'm able to move the tree around as well as zoom it in or out. If I click on the line again, the model rehighlights and everthing is back to normal.
It was quite confusing as to what was going on until I happened to figure it out. Is this functionality or a bug?
Thanks..
Thanks..
AJ Troglio, Manufacturing Engineer
The Boeing Company
St. Louis, MO
RE: Specification tree moves. Bug or functionality?
tools>options>general>display>tree manipulation
there are a few options there that you can choose
hope it helps
Thanks....
The Boeing Company
St. Louis, MO
Have you discovered you can zoom the tree to make the text larger or smaller?
Another trick is to use F3 to switch the tree off or on.
....Jack
Boeing Everett
Thanks to all for the help
AJT
The Boeing Company
St. Louis, MO
It is a good practice to choose the geometry from the tree, because u can do something OR make NC motion on it, even it is in HIDE mode.
If u have a big tree, just right click the graphic geometry and "Center graph", it will bring u right on the tree.
Have fun.
you can switch from tree/geometry with :
-SHIFT + F3
-clic in the tree
-clic on the bottom right white axis
you can zoom the tree when tree is active with
mouse center + mouse right and move up/down
you can zoom tree when geometry is active with
CTRL + wheel
Eric N.
catiav5@softhome.net
Sandeep
