Measuring shaft bearing journal OD
We currently use mechanical snap gauges when trying to measure the OD of shaft bearing journals.  After conducting a gage R & R, we found that well over 30% of our bearing journal tolerances are consumed by error in measurement.  Has anyone been successful with any other technology.  Our runout tolerance is +/-.001 TIR.
RE: Measuring shaft bearing journal OD
I am curious, what is R&R?
eaglet - Laser micrometers have repeatability on the order of ±0.0006mm, or approx. ±0.000025 in.
electricpete - "Repeatability and Reproducibility", which is rather misleading, since the values in an R&R study actually represent error...
