error during check-in
I have an assembly which I would like to check in to the PDMWorks vault. I am receiving the following error during the check-in process:
Unable to write custom properties to the file "XXXXXX.SLDPRT". Please make sure that the file is not being used by another program.
The part in question does not currently exist in the vault, and I am able to modify the part properties within Solidworks. What is this error attempting to tell me?
Dave Gowans
Dave Gowans
RE: error during check-in
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Correct me if I'm wrong, but wouldn't I be unable to log in to the vault at all if the versions were inconsistent? In the past, I think I remember being notified upon login that the vault was newer than the client and being able to update the client automatically.
Dave Gowans
Some other brainstorms:
-make sure there is only one Solidworks & PDMWorks process running
-make sure the document you are checking in is write-enabled (PDMWorks "Read-only for referenced docs" option forces you to have ownership of the file to be able to edit it)
Bradley
