Graph Problem Displays Zero Values
4
In Excel - Graph showing data from a table has lines showing zero values for cells with zero values, screws up the appearance of the graph with all those colored lines and when data is "short", there is no data for the last values in a column, then the line with that short column of data drops to zero even though there is no data.  I know of no graph command telling it to ignore zero values.
Graph works fine if the cells in the table are blank, but if the table has formulas resulting in 0 the graph shows lines for all those zeros.
Have tried hiding the zeros with IF statements, no worky, cells show blank but graph still picks it up as a zero.
Have tried:
IF(C6=0,"",C6*.433)
0;-0;;@
I even turned off the Display Zero option for the worksheet.
PUMPDESIGNER
RE: Graph Problem Displays Zero Values
4
You need to replace the 0 with NA.
If the cells are formulas then do something like
=if(a1+b1=0,na(),a1+b1)
if your cells are just entered then you may need to create a new line of data e.g.
=if(a1=0,na(),a1)
THis should remove the line to 0.
Hope this helps.
maybe only a drafter
but the best user at this company!
Thank you very much onlyadrafter.
Worked perfect.
Wish I could return the favor somehow.
PUMPDESIGNER
Pumpdesigner,
There's not much you could tell 'onlyadrafter' about Excel. However, to return the favour read the groups in your areas of expertise and help someone else.
MRG
http://www.analysis.demon.co.uk
