How to get command-line arguments in Windows application?
I want to parse command-line arguments of windows application. The windows application main entry point is _tWinMain (or WinMain).
There is no indication of the argv/argc parameters. The reason I need them is because I want to use the getopt function.
Therefore, I need one of 2:
1. Get the argv/argc arguments and use getopt.
2. Use some utility function of windows that does the same.
Best regards,
Erez
RE: How to get command-line arguments in Windows application?
I am pasting below (From MSDN) the description of WinMain function.As given below lpCmdLine contains the arguments passed to it.
WinMain
The WinMain function is called by the system as the initial entry point for a Win32-based application.
int WINAPI WinMain(
  HINSTANCE hInstance,      // handle to current instance
  HINSTANCE hPrevInstance,  // handle to previous instance
  LPSTR lpCmdLine,          // command line
  int nCmdShow              // show state
Parameters
hInstance
[in] Handle to the current instance of the application.
hPrevInstance
[in] Handle to the previous instance of the application. For a Win32-based application, this parameter is always NULL.
If you need to detect whether another instance already exists, create a uniquely named mutex using the CreateMutex function. CreateMutex will succeed even if the mutex already exists, but the GetLastError function will return ERROR_ALREADY_EXISTS. This indicates that another instance of your application exists, because it created the mutex first.
lpCmdLine
[in] Pointer to a null-terminated string specifying the command line for the application, excluding the program name. To retrieve the entire command line, use the GetCommandLine function.
nCmdShow
[in] Specifies how the window is to be shown. This parameter can be one of the following values.
