SW crashing with large assy's
Our entire user base is experiencing a problem that only seems to be getting worse as our project progresses. The larger our assemblies become, the more often SolidWorks crashes when we try to do basic things, like save the assembly files and check them into the vault. We have been unable to check the top-level assembly file into the vault for several weeks because SW consistently crashes.
Here is what we have done so far to try and prevent the crashes:
Local Settings / Temp directory is emptied out each day through a logon script.
I have tried a Repair as well as an uninstall/reinstall on both SW and PDMW. Neither of these actions improved the situation.
Both hard drives on my machine have been defrag'ed within the last week.
RAM, processor speed and hard drive space are not the issue. I have 2 GB RAM (plus a 4095 MB swapfile -- the max allowed under Win2k), a 2.80 GHz Pentium 4 and plenty of free space on the hard drive.
Have I missed something in attempting to pinpoint the cause of these crashes? Any advice/suggestions are always appreciated.
Thanks!
Thanks!
RE: SW crashing with large assy's
What version of SW?
If your running XP, what SP?
Since you did mention Win2000 - What SP is that on?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
SW2004 SP04.2
Win2k SP4
Thanks!
For crashing on saving, minimizing the amount of data that needs to be saved (suppressing all components before save) and turning large assembly mode OFF before saving (???) seems to help.
Are you choosing to resolve all parts on check-in? This can cause problems, even though it's "recommended"...
Also - make sure your assemblies and parts are free of rebuild errors and circular references and lock all external references, only unlocking as you need them.
The crashes do seem to occur more often when I try to resolve all components, but how can I choose not to resolve all parts on check-in? According to the PDMWorks help, all components in an assembly must be resolved before you can check-in the assembly.
What version is your PDMworks and what SP? I would hope that your PDMworks vault and client are the exact same SP and that the SP of SW is the same as the vault? I talked to SW about this just last week, and their recommendation for best performance is that the SP of SW is the same for the vault and the client as well.
Scott Baugh, CSWP
FAQ731-376
We are running PDMWorks 2004 SP3.0, which does not match the SP for SolidWorks 2004 SP4.2. However, we have been able to reproduce the crash in SW2004 and SW2005 with PDMWorks turned off, simply by trying to save the assembly to disk.
Yep, that is about the real world limit of the 32-bit windows operating system. ANY 32-bit OS can only manage a maximum of 4GB of memory. In the case of Windows, it reserves half of all available memory for itslef, leaving 2GB maximum for any single application (theoretically, in practice 1.6-1.7 GB is more realistic, as you have noticed).
If you do some searching here and at comp.cad.solidworks, you will find some info on enabling the 3GB switch. This will allow SWX to access up to 3GB (theoretically) while reserving 1GB for the OS. Users have had mixed results with this setting and it can be quite dangerous if implemented improperly.
http://www.d-digest.com/ssa/v3i1/model_tips_review...
Thanks for the help!
DO NOT use the 3GB settting on XP SP1 ... your system could freeze if you do ... apparently a hotfix from Microsoft is needed to allow the 3GB switch to be used.
Also note that this is not supported by Microsoft.
Added "/3GB" after the last line, rebooted, and system is running, but not sure if I notice an increase in performance yet. What should my min. and max. page files be set to for optimum performance?
I also took tech supports advice and turned on "geometry pattern" on my linear patterns where possible.
