How to convert to and from Mictostation
I need to convert a bunch of AutoCAD drawings to Microstation and from Mictostation to AutoCAD. Any ideas out there?
RE: How to convert to and from Mictostation
You can do this from within Microstation in J or V8.  Use the import/export commands to open a .dwg or save as a .dwg.  V8 does it better, but you do get a usable drawing from MS J.
Mike
mike8 - I was given some microstation files from an overseas customer but I only have autocad.  Is there a conversion method out there?  Does anyone have MS they could use to convert these files?
IFRs
I will be happy to try for you.  Send me a file at ms2acad@yahoo.com.  If the resulting .dwg file is ok, I can then do the rest for you.
Mike
