Wind Load on an Open Top Rectangular Tank
I am designing an open top rectangular SBR and am wondering the best way to consider wind load on the structure. I am designing per ASCE 7-02 and the tank is only going to be out of the ground about 11'. The remaining 14' is buried. I am not so much concerned with the wind pressure as with the wind suction being combined with the internal fluid pressure which is controlling. Normally I would have used Eqn. 6-20 for wind loads on other structures, but then I got to thinking about the potential for suction forces. Am I picking gnat crap out of pepper or would the components and cladding equations be better suited for this situation? How are you guys handling this? Thanks in advance.
RE: Wind Load on an Open Top Rectangular Tank
Wind loads do have a bigger effect on steel tanks, especially when empty.
I am like Jedclampt, if the tank is full; wind is not going to govern. If it is empty, I still don’t think it will govern because the earth pressure will be your worst load case.
Good luck
Thanks again to both of you for the quick response!
