SW's Layers & Dims/Notes/Annotations
Can SolidWorks be set up to AUTOMATICALLY put dimensions on a particular layer (I'd create an Annotations layer)? I can't find a way to do so.
How about notes & annotations such as hole callouts & weld symbols... can they?
Why, you ask? I'll be exporting DWG files to a person who needs geometry only. They'll open in Illustrator, and have the capability to turn off or delete layers. If I could get everything but geometry onto specific layers, then I would have nothing to do but export the file.
Alternatively, could geometry be automatically placed on a specific layer? This would accomplish the same thing.
I do realize that there are other options (a custom VBA program could throw out everything but geometry)--I'm just exploring my options at this point.
PS--If any of you have a need to share files between SW and Illustrator, there's a plugin for Illustrator called CADGate that seems to do a pretty nice conversion job--much better than Illustrator's out-of-the-box capabilities. Check it out, & thanks in advance for the help...
Brian
Brian
RE: SW's Layers & Dims/Notes/Annotations
There is nothing that is automatic in SW for creating Layers and placing items on a layer, but if you have layers setup in SW already you can export those settings out to SW to DWG using a Map file.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
