Internal error: Memory Access?
Greetings!
I have recently started running into a problem opening parts from TeamCenter.
I click on a part in TeamCenter, and while opening the part in UG, I get a "ugraf" error reading:
    The following error occured whilst responding to an iteroperation request:
    Internal error: memory access violation
I click OK, and it appears as though nothing has opened, however I can go to Window --> More --> and the part I just tried to open is sitting in the list.  I click on the part, and it shows up immediately with no problems.
Has anyone else run into this, and if so do you have a fix for it?  It seems like it is a memory error, but I'm baffled as to why it would start occuring all of a sudden.
May be a problem for the GTAC folks...
Grant
Aerospace Engineer
RE: Internal error: Memory Access?
Hi all,
Just an FYI to all who've had to problem I listed above, I found out the fix to the problem is to clean out the UG Temp directory.  Mine had about 500mb of junk files in it from UG sessions gone awry.
Make sure you save your parts and close UG before deleting ANY of these files or they may become corrupt.
Grant
Aerospace Engineer
