Access help docs on web server through Catia
I would like to be able to access the online help documentation by pressing F1 in Catia V5R13.  We have loaded on an offsite webserver.  I was instructed to put the web address in quotes in the Tools/Options section of Catia but Catia is not letting that path remain.
Any suggestions?
thanx...
RE: Access help docs on web server through Catia
HI,
define the path in the ENV file. B U T :
if you define the path using WWW. your users will not be able to load file from online doc if the extention is longer than 8 characters :  good for CATPart but not good for CATProduct, CATAnalysis, CATProcess...
please reconsider the www choice, do that for your users  ;)
Eric N.
catiav5@softhome.net
