undervoltage lockout for 3953 H-Bridge Chip
i'm using the chip as a current limiter on a dc motor, but i also want to use it as a low voltage cutoff circuit.
i have the chip connected to a mosfet which will switch the motor on and off. i'm using a 14.4V battery and have a resistor network set up when the battery level drops below 11.1V it will turn the mosfet off. the chip has an internal undervoltage lockout feature but i don't know what pin it corresponds to.
if anybody knows i would appreciate it a lot.
RE: undervoltage lockout for 3953 H-Bridge Chip
Amazing what you can find through Google:
http://www.allegromicro.com/sf/3953/
If we learn from our mistakes,
I'm getting a great education!
