Bends and flat patterns
Is it possible to control the sequence of a flat pattern and insert it in a draft?
For example if you have a "U" shaped part usually when you press flat pattern the part goes from fully bend to fully flat no steps in between,i would like to be able to show the bend sequence one step at a time and export it in my DRAFT.
RE: Bends and flat patterns
