Connect Checker
Connect Checker
Hello:
As a result of connectivity check, I am getting a number of edges that need to be fixed. What can I do to fix them all? The gap between the edges where the errors are found ranges from 0.01 to 0.035. Changing the merging distances in Join and Heal functions did not work. Is there any other feature that resolves this issue? Thanks.
-Raghu Kadava
-Raghu Kadava
