Output/Print/Display Material Properties
Hi
Does any one know how to request displaying the material properties being use in each step in Abaqus (how to request it and look at it )
For instance i would like to use Young modules= 160 in step 1 ... then Y modules=300 in step 2.... is there a way where i can do an Element print or something to see what value is it using in that step.
Gabriel
Gabriel
RE: Output/Print/Display Material Properties
the material is part of the model data, your load steps are part of the history data.
I think that you need a model for each Young Modulus you want to calculate with.
Greetings Tamlin
corus
You can prescribe values of field variable in each step for a custom defined set of nodes/elements or you can use UFIELD subroutine (at a nodal level during each increment). Such that your material property will locally change acording to the associated field variable during each increment.
Values of field variables can be adjusted also by using an associated amplitude curve.
->Field variables can be requested as output.
There's a useful example in Abaqus/St. User's Manual v6.3(or ABAQUS Analysis User's Manual v6.4) - Chapter:19.6.1. "Predefined fields " -> Section "Field variables"
