SOFTWARE DELAYS AND MOTOR STARTING
I have the task of installing an alarm system for pumps (motors) that are started remotely at our plant (Safety Issue). We use the Honeywell TDC system. My initial approach would be to take advantage of the TDC and the motor control circuit by installing some sort of delay. Simple enough.
Any suggestions?
RE: SOFTWARE DELAYS AND MOTOR STARTING
Can you give to me the model/type of TDC honeywell system you have? I'll try to check in our product list for you to have simple task to do. Maybe you have spare points in it. Let me help.
Suggestion: Visit
http://www.harrisas.com/
for TDC 2000 or if you migrate to TPS/TDC3000 platform. The latter achieves the operational efficiency and safety. It is also an open automation system with OPC (OLE for Process Control) interface standard.
