WILDFIRE: How to PivotDir Sweep????
ARRRGHHH!!!
Please help me learn how to do a Variable Section Sweep--> Pivot Dir sweep as in 2001. I see a drop down option for "Constant Normal Direction" in the Variable Section Sweep feature, but I can't seem to get the sketcher to open.
In 2001, all you needed was a trajectory and a normal reference plane that constrains your section...I'm not sure if that has changed.
Thanks for any help!
RE: WILDFIRE: How to PivotDir Sweep????
Hey all,
I figured it out...its simply renamed to the "Normal to Projection" option under the references flyout menu.
