Derived configurations
I am having some trouble with derived part configs. I created a few derived configs of a default part config. Then I want to make additional features that should only be applicable to certain of these derived configs. The problem is: after I create a feature in a derived config, I have to go back through all the other configs to suppress that feature in them. This could be time consuming and I might even miss some information if I have lots of configs and features. Is there a way so that if I create a feature in a derived config, it should AUTOMATICALLY show up as unsuppressed in all the other configs?
Thanks to all the readers
RE: Derived configurations
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
In SW05 when you use a DT to make your Configuratons (Only). There is a bug that toggles "Suppress Features" off, and if you don't catch that early then you will be SOL and have to manually fix it for each Config... Been there done that already this year.
Scott Baugh, CSWP
FAQ731-376
