Panel weight and capacity of the crane
To determine the capacity from the crane when the panel is lifted from floor it is necessary, in addition to the weight of panel, to keep in mind an additional factor for the suction effect with the floor? That value is the factor?
I wait their answer of help
RE: Panel weight and capacity of the crane
Many times when we are dealing with work in place and have to also pick against adhesion, friction or suction it is best to have the most next highest rated crane for your operation to save time and sleep!
