What recommedation for tank coating for liquid sulphur
I have to install a tank (12m dia.x 8m high) to hold moltem sulphur. Sulpur will be heated to 120 to 180deg. Corrosion of the floor has occurred in similar tanks before. I am considering Carbon steel with coating. What recommendations can be made. Alternates are Carbon steel, with stainless linings or solid stainless?
RE: What recommedation for tank coating for liquid sulphur
You are limited in choice due to the operating temperatures stated. There are some vinly esters available that will handle these temperatures, however, these are expensive and require very skilled appicators to ensure the integrity of the applied coating.
A more enconomical option would be to investigate the use of inorganic zinc silicates, in all cases you must consult the material manufactures and seek their advice.
Ron Berry
Coatings Consultant
Magellan Technologies Limited
New Plymouth
New Zealand
ron@magellan.co.nz
Is there a "recipe" :) for making old/antique mirrors....where they have the spotted look...and look slightly golden around the edges.....sure would appreciate some input.....Thank you anyone...who can answer this request....Help!!
