SW2005 CRASHING
SW2005 CRASHING
Having recently installed 2005 ,it keeps crashing for no apparent reason.I am running it on Windows XP.Yesterday I updated to windows service pack 2 after been advised by my support centre and I also updated the SW service pack to 0.1,I'm still having the same problem.Is there anyone else having this same problem and do they have a solution to stop this.I anxiously await your feedback.
RE: SW2005 CRASHING
2) Have you tried doing a repair on your SW Install? - FAQ559-908
3) What are you doing when it crashes?
4) What are your other Computer specs?
5) Have you cleaned out your TEMP files lately? - FAQ559-884
Answer these questions and maybe we can help further.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: SW2005 CRASHING
2) Have you tried doing a repair on your SW Install? - FAQ559-908 - No but I will (I done a clean uninstall before I loaded the service packs,it shouldn't be this)
3) What are you doing when it crashes? - Apart from been close to putting my fist through the screen I just restart SW again
4) What are your other Computer specs? - Dell workstation 2.2Ghz 1 gig of ram 40Gig Hard disk
- No but I'll do that too,to see if it helps.
RE: SW2005 CRASHING
3) What are you doing when it crashes? - Apart from been close to putting my fist through the screen I just restart SW again - I take it from the response it's widows that is crashing and not SW? If it's SW then... when is it crashing and what are you doing?
4) What are your other Computer specs? - Dell workstation 2.2Ghz 1 gig of ram 40Gig Hard disk - what is your Virtual memory set too?
Scott Baugh, CSWP
FAQ731-376
RE: SW2005 CRASHING
3) What are you doing when it crashes? - It's Swx thats crashing,found it in drawing mode a couple of times when I was editing a section line but it's not down to that all the time.
4) What are your other Computer specs? - Dell workstation 2.2Ghz 1 gig of ram 40Gig Hard disk - what is your Virtual memory set too? - 1536MB
RE: SW2005 CRASHING
I think this is probably fix your issue.
Scott Baugh, CSWP
FAQ731-376
RE: SW2005 CRASHING
RE: SW2005 CRASHING
RE: SW2005 CRASHING
Scott Baugh, CSWP
FAQ731-376
RE: SW2005 CRASHING
Thanks for all your help.
