Giving work to CAD operators
Up until a few months ago, I had done all analysis and design as well as the drawings. I now have a CAD operator working with me, and I'm struggling with getting him the information needed to complete my designs. It seems so much simpler for me to do the drawings since everything is in my head. I feel like I'm spending more time going back and forth with the drawings now than I did before.
I'm curious what others are doing and how they are making efficient use of CAD operators. What can I do to make the transition from my designs to this person without increasing the time spent on the project? I feel that if I have to sketch something out on paper, I could have just input it into CAD and been done with it.
RE: Giving work to CAD operators
At first, it may be time consuming but over time, with proper training, the drafter will learn what you expect of him.
I've seen structural firms with different philosophies about structural drafters. One favors a drafting team led by one or more strong drafters (like a seasoned Sergeant who is able to train young Lieutenants). Other favors drafter to be tracers where engineers provide literally "everything". There are pros and cons for both although I tend to favor the former.
I'm not sure what the experience level of your drafter is. If he is not very experienced, you will have to be very patient at first and start training him. Otherwise, be ready to pay extra for a higher level drafter (very hard to find).
As for engineers performing CAD work.... There are two philosophies about this as well (at least). I tend to not allow engineers to perform CAD work as engineer's hourly rate is higher than the drafter's. This can be different in a very small office setting, however.
I would like to hear your thoughts on this as well.
Good evening.
Yes, you might do it faster the first time through, but what about those changes you have to make later on?
If you can visit his desk during your breaks and see how the things are going, you will not regret the time spent. Initially it looks like that you are wasting time, but in long run, as the operator picks up with your expectations, you actually end up saving a lot of time for more important engineering stuff.
BFN
What has not currently been discussed is the quality of the CAD operator. Is he any good? A good CAD operator is a rare thing indeed and deserves every bit as much respect as a good engineer.
Once a relationship has developed between engineer and CAD operator productivity is likely to increase as each person is allowed to focus on their own strengths.
For my own part, I use CAD operators to set up drawings, reference model files, set up layer naming conventions, check dimensional accuracy and draft details without intrusion from me. As an engineer I try to supply member sizes, sketch details, notes and basic plan information. Outside of these areas there is of course plenty of scope for overlap. As I can use AutoCAD to some level of competence, It often makes sense for me to develop details at complex areas of geometry rather than trying to explain to the CAD operator. I’m unlikely to go as far as full annotation of the detail.
Cynically, also note that engineers are paid more than CAD operators. If you want to be a CAD operator expect a pay cut.
One more thing I would like to add is the fact that computer and AutoCAD is just a "tool" for CAD operators. New and improved pencil/eraser... What they are really getting paid for is the actual content that they generate using AutoCAD.
There can be a young CAD operator who is extremely fast and know all the latest functions in AutoCAD. However, he is no match for a drafter with years of experience and know how buildings are put together. This knowledge is something you can't learn in school.
In a large office setting, you need both to complement each other. Juniors getting trained by not only engineers but senior drafters who knows his stuff.
Currently I do all my own drafting as well as engineering as I have for about 3 years now. Some friends of mine at better firms where the engineers do engineering and drafters do drafting use the method I described above and say it works great for them and seems to make a lot of sense to me. I think I'll give that a shot when/if I get my own drafter. The hard part is compiling a library or list if you don't already have one.
If you are forever doing new stuff that no one at your company has ever done before, it could be frustrating either way. But if you tend to do the same or similar things, your CAD operator should need less and less input from you to put out the finished drawing.
I've seen CAD operators without enough basic math skills to do the layout they needed to get their drawings done. That is obviously a big slowdown.
I am a young engineer (relative to the profession) that has been having the same experience. It is hit and miss with the drafters. In sum, I use the drafters about 33% of the time.
A further problem is when the boss asks me to divide up the time spent drafting and time spent designing--similar to trying to dividing up the time typing and writing this response! I can type about as fast as I can speak or think, and definitely faster than long hand. So, how much time should be allocated under the catagory typing? The secretary is similar to the drafters, I use the secretary about 33% of the time.
Generating CAD vector images is part of my engineering design process. I'm a little jealoous or envious of the older engineers that have the clear seperation of drafting and engineering.
On a side note, engineers should also develop typical design calc library for most common structural design applications to refer to.
Once a company has these two, then you staff up with drafters with varied levels of experience. Many of the youngsters from local technical schools are quite knowledgeable in CAD already.
They will now learn the office CAD standards from the first guy and learn about structural drafting from the older guy.
This is my view of an ideal office setting which works for me.
If the office is very small... as in one or two drafters, engineer must carry the burden of training them.
