Hole wizard error
Hole wizard error
Hole wizard error
I am trying to insert a hole in a part using Hole Wizard. But I get the error "Points to locate holes are not constrained". I already added all the dimensions to properlt locate the holes, so I am not sure what's going on. Your suggestions will be appreciated.
RE: Hole wizard error
Sounds like a 3D space error, yes.
Make sure you have a start plane selected before firing up the hole wizard.
System: Dell Precision 650—Intel Xeo @ 2.66 GHz with 1/2G RAM
OS: Windows 2000 SP3
Graphics: NVidia Quadro FX 500 128Mb (OpenGL set to Solidworks)
Version: Solidworks 2005, SP0.1
