Hardware question Processor vs. RAM
I have a couple of SolidWorks workstations that I am looking to upgrade but my budget has me torn between giving them 2gig of RAM instead of 1gig or dual processor instead of a single 3.2gig processor.
The question my designers have is whether or not it will make a different when running another piece of CAD software along with their current running copy of Solidworks.  Right now when we look at Preformance monitor on their current 1gig/2.8gig machines we commonly see the processor burried at 98% but only 400meg of RAM in use.  This would lead me to believe a second processor would be more important when wanting to start another instance of Solidworks or an instance of ProEngineer/AutoCAD.  I just wanted to get all of your opinions before I made the decision.
Thanks.
-Al
RE: Hardware question Processor vs. RAM
It really depends on what you are doing.  SW is not designed to make use of dual processors, but I have seen instances using COMOSworks where both processors have activity, and where I can continue modeling items while running FEA in another session.  I have dual 1.7 P4 with 1gb of memory.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Al,
Check out the FAQ section Madmango did a write up on system requirements which also has a link to SWx corp website.
Best Regards,
Heckler
Thanks for the input.  I think the FAQ that Scott posted answered my question.
thanks VERY much.
-Al
