Moving or copying data from old start part to new start part.
Question. I have some data from a supplier that is in a old start part. I want to move or copy some or all of the data from old start part to new start part.
Any techniques are gratefully taken. Texaspete
RE: Moving or copying data from old start part to new start part.
If it does, and you want to copy parameters, then make a dummy assembly with both old and new parts and just create and copy the parameters from the column entries in the Model Tree.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
To copy geometry, it all depends on how different your new part will be from the original. Are you copying the complete part over (no references), or just want to copy a few features (use UDF's). I need more details.
Steve
I Hope this helps. Texaspete
Michael
