New PC's...Need some help...quickly...Please!
I just found out we are getting new PC's. Below is what they are ordering. I'm going to ask to bump up the RAM and we get us some video cards. Anything else we should request to change?
Base Unit:
OptiPlex GX270,2.80GHz,Pentium4,1M Cache,Gigabit NIC,Small Minitower,800 Front Side Bus (221-6151)
Memory:
512MB, Non-ECC,333MHz DDR 2x256,Dell OptiPlex (311-2864)
Video Card:
Integrated Video - Intel DVMT,GX260/GX270 (320-0428)
Hard Drive:
40GB EIDE, 7200 RPM, ATA/100 Hard Drive, GX260 (340-8889)
Operating System:
Windows XP Professional
Base Unit:
Memory:
Video Card:
Hard Drive:
Operating System:
RE: New PC's...Need some help...quickly...Please!
I would also get a good video card. I'm not sure SWx will run on those integrated cards. I would do some research on that....FAQ section has something on Video Cards
Best Regards,
Heckler
No SW will not run worth a hoot on an intergrated card. Get one of the FX Quadro series cards.
FAQ559-986
http://www.scottjbaugh.com/Tips_Tricks/Hardware%20... - This was made when SW2004 was the latest.
Scott Baugh, CSWP
http://www.3dvisiontech.com
FAQ731-376
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Follow Heckler's advice. A 40Gb drive is not nearly enough, but you should separate program files from data files. I'd recommend two SATA drives (not using the RAID config, but keeping the drives independent).
Be very careful about the motherboard issue. If you can't upgrade the graphics card, or if your AGP slot speaks slowly, you'll get nothing from this computer system concerning SolidWorks. (Sounds like someone forgot to do their homework before specifying the systems.) Check the system requirements at the SolidWorks site for video cards and other things. This is critical and cannot be ignored or you will see nothing on your screen (except, maybe blue). The motherboard also vitally affects how quickly each component transfers data to other components (a major benefit of the 64-bit systems--architecture).
I'm sorry if I seem critical--just seems like the process is a tad backward in this case. These things are very important to get hammered out before ordering or you might have a lot of nothing on your hands.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
Scott Baugh, CSWP
FAQ731-376
