Weldment - bent tubing...
I have a lube skid at one end & a bearing at the other. I want to route some bent tubing from the skid to the bearing. I can insert a weldment feature on a 3d sketch - with fillets - & then make it show-up as one piece in the cut list - no problem. But this tube is one piece of a larger assembly. I have to create a separate sheet in my drawing file with a view of the tube part so I can make my cut list. Is there a way to get the cut list on the same sheet as the whole assembly? (2005 SP0.0)
tatej usfilter.com
RE: Weldment - bent tubing...
No I don't think there is. I know this was a Limitation in SW04 (If I understand your problem correctly). So if you can't add it in SW05 then I would say it still is (Without my trying it here)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
