slip on pipe flange
slip on pipe flange
If you use a slip on flange on the end of a pipe, where and how would you weld the flange. I assume that fillet welds would be used, but would not know what size of weld to use. This is on a low pressure pipe.
RE: slip on pipe flange
You first set the flange so that it projects (pipe thickness + 1/8") from the edge of the pipe, then you make the internal and external fillet welds around the circumference.
I believe extra 1/8" is provided to protect the gasket surface from distortion.
-Christine
If pressure is very low, the weld sizes could probably be reduced- depending on what code or standard pipe is designed under (if any).
and as minimum weld, cover the pipe but not less than 1/4" legs. I assume that this is not a Coded job.
ER
The answer to your question is contained in the fabrication section of the ASME B31.1 and B31.3 piping codes.....
By the way, S.O. flanges should always have two fillet welds (inside and outside the pipe)to attach them to the piping systems.
Check this thread...
http://www.eng-tips.com/viewthread.cfm?qid=105019
and this one...
http://www.welding-units.co.uk/Flanges/about_flang...
MJC
The set back distance is to avoid damaging the flange face with the inside weld, and for pipelines, pigging considerations. Some codes specify a dimension, others such as ASME B31.3 do not. The set back dimension is not signficant with respect to strength or fatigue considerations.
The inner weld is always preferred, but not always required. You need to check the applicable code for requirements. When required, it is generally a small fillet weld (e.g. 1/4 inch or the thickness of the pipe, whichever is less).
