piping system simulation
For my personal education I would like to develop the math system (differential equations?) to simulate a simple home water supply system.
System Description
Well or tank supply (various water levels)
>pump c/w pump curve
>bladder expansion tank (PV relationship)
>piping friction losses
>water tap discharge at different flow rates
A active variable plot during system operation would be nice.
Any recommendations on where to start? Thanks.
System Description
>pump c/w pump curve
RE: piping system simulation
* Level of detail
* Accuracy you want
* List your assumptions
* Load cases you want to look at
Sketch typical system of interest and label nodes
Roll up your sleeves and go to work
And do you want a steady state or dynamic model?
Matlab / Simulink is good software to solve differential equations and make dynamic simulations.
http://www.mathworks.com/
Cheers,
C.
http://mysite.wanadoo-members.co.uk/pressure_drop2
Feel free to use part of my program if you wish.
Good luck and happy learning!!
<General> As this is a learning exercise I would like to create/setup the differential equations myself
so a paper or textbook describing this would be an asset.
There a several good books on the mathworks site i.e.
Computational Methods for Process Simulation
W. Fred Ramirez
This book presents a time-domain approach to modern process control and is written for students and professionals in chemical, control and instrumentation, and process control engineering.
http://www.mathworks.com/support/books/book1678.ht...
What you typically need to do is to set-up the dynamic mass and energy balance of the tank-pump-pipe system.
Some of the (steady stae) equations you are looking for can be downloaded from my website: www.carf-engineering.com
Hope this helps,
CARF
