Is Sheet Format an implicit block ?
When you edit sheet format, are you editing an implicit block ?
Asking, because if it is then it would explain certain things (problems) - thou not all the problems I have
RE: Is Sheet Format an implicit block ?
When you eidt sheet format your editing the sheet format.
You can save those Title blocks off as files File\Save as Sheet Format - which is something all users should do.
But to answer your question - No it isn't a block.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
