Basic Tripler Circuit
I've designed frequency doubler (.005-3GHz & 1-11GHZ) using bridge quad diode using core and wire for the lower freq & microstrip for the higher frequency band.
I need help on designing low frequency tripler with input from 50-150MHz & 240 -375MHz, +10dBm power input & +15Vdc.
I'd like to know the basic design/circuit?
Krytar
Krytar
RE: Basic Tripler Circuit
http://www.wenzel.com/documents/hints.htm
I checked on Wenzel's papers, and found one of his article on RF magazine is very interesting. From a mixer doubler topology, where a bridge quad is used, he rotates the quad to move the common cathode (from the output) to the next arm connection. Voila! he transforms an even-mode to an odd-mode mixer multiplier.
I'm using Wenzel's topology to turn my frequency doubler into a tripler. Will post the result if it works at all.
Does anyone know if Charles Wenzel is related to Bob Wenzel (a RF/Microwave filter guru)? I worked with Bob on some multiplexers sometimes ago.
Krytar
It works!
My tripler works! I used Wenzel method using a Metellic bridge quad diodes to convert sinewave to squarewave.
Inject 300MHz signal to input port, I've got 900MHz signal output @20dB loss with 56dB fundamental suppression, second harmonic is way down at noise floor.
The conversion loss is high (will be taken care off by adding a cheap amp at the output). Bandwith is a bit narrow: 280-340MHz (for 840-1020 MHz output).
Thanks everyone
Krytar
