Changing Default Settings
Before upgrading to SW2005, I am creating a 'batch update' macro that will load all of the default templates using the following code:
It works great with one exception. The line that adds the swFileLocationsDocumentTemplates only adds the second folder, not the first as well. Is this a limitation that you cannot add multiple folders of templates using the SW API? I have tried doing something like "H:/fdsfs" & "H:/fsdf" and that doesnt work either.
CODE
Dim swApp As Object
Dim Part As Object
Dim retval As Integer
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
swApp.SetUserPreferenceStringValue swDefaultTemplateAssembly, "H:\SolidWorks\Standard Templates\Radial Assembly.asmdot"
swApp.SetUserPreferenceStringValue swDefaultTemplateDrawing, "H:\SolidWorks\Standard Templates\Drawing.drwdot"
swApp.SetUserPreferenceStringValue swDefaultTemplatePart, "H:\SolidWorks\Standard Templates\Radial Part.prtdot"
swApp.SetUserPreferenceStringValue swFileLocationsDocumentTemplates, "H:\SolidWorks\Standard Templates"
swApp.SetUserPreferenceStringValue swFileLocationsDocumentTemplates, "H:\SolidWorks\Skin Templates"
swApp.SetUserPreferenceStringValue swFileLocationsBOMTemplates, "H:\SolidWorks\BOM"
swApp.SetUserPreferenceStringValue swFileLocationsMacros, "H:\SolidWorks\Macros"
retval = MsgBox("Settings Update Complete ", vbExclamation, "Settings Wizard")
End Sub
Dim Part As Object
Sub main()
End Sub
RE: Changing Default Settings
Try doing both with a single command, sorta like swfilelocatoinsdocumenttemplates, "blablabla" _
"blablablablabla"
Just tried that and had no luck. I am coming to think that it is simply a limitation; a stupid one but hey, I guess that is was upgrades are for.
Example: "H:/fdsfs"; "H:/fsdf" or "H:/fdsfs", "H:/fsdf"
This macro is a good idea!
Good Luck
Tried both, no luck still. I contacted our VAR and they are looking into it as well...good brain teaser for an election day!
As for a possible solution, it appears that the second entry is overwriting the first. Try entering the two locations as one string separated by a space, comma or semi colon (Not sure about the proper syntax). It's stored in the registry as just one string for that entry.
Jason Capriotti
Smith & Nephew, Inc.
How do you normally write the registry file? What is the deliminater between the two files? I have tried a combination of strings as well as a combination of file locations within one string. Thanks for everyones help.
Got it to work. I used Gildashard's idea with creating one string as follows:
"H:/asdf/asdf;H:/qwe/qwe"
When I wrote my last post I had this:
"H:/asdf/asdf ; H:/qwe/qwe"
I guess the spaces make a difference! Thanks again for eveyones help.
Jason Capriotti
