Air flow distance from nozzle
Hello!
I need your help with this...
Through a nozzle with diameter 5 mm, there is an air flow. The mass flow is 0.01 kg/s, and the flow is horizontal. The air flows into air with atmospheric pressure. How far will the air flow reach before the velocity is zero? Or even better, is it possible to calculate how the velocity varies with the distance from the nozzle? I know its hard to calculate an exact value, but an estimation would do. Seemed so easy, but can't figure it out...
RE: Air flow distance from nozzle
Theoretically, the velocity won't ever reach zero.
But isn't there a way to estimate at what distance from the nozzle the speed has decreased to a certain speed? I only need a rough estimation...
I have exactly the same problem, trying to eximate roughly the velocity distribution outside a cylindrical nozzle. You told you found a way around. Would you mind telling me your approach? thanks a lot
