AutoCAD Solid Volume Errors
Hi, I would just like to find out if anyone else is having similar problems with AutoCAD 2004
When subtracting a solid from another (i.e. decreasing the size of the original solid), it sometime happens that the volume of the original solid increase (by as much x10 000 in my case) rather than decreasing as is should. Seems a little strange. The file has been audited, purged etc. but the problem still persists
RE: AutoCAD Solid Volume Errors
I can't say that I've noticed the problem you mention.
can the problem be repeated ?
I was able to repeat the problem (actually couldn't stop it from occuring) and eventually had to copy and past the solids that didn't have any problems into a new drawing and continue.
Strange thing was that if I copyed the solids from the new drawing into the corrupted one say three times, I would get different volumes for exactly the same solids and these volumes would also differed from volumes calculated in the new drawing
http://www.theswamp.org
www.cadtutorforum.net
