Allowable nozzle loads - ANSI/HI 9.6.2-2001 - what pumps comply?
Guys are any of you familiar with the ANSI/HI 9.6.2-2001 standard? This is the standard setting forth allowable nozzle loads for ANSI centrifugals. Do any of the current manufacturer's offerings comply? I bet they don't. This is the first I've heard of it. Thanks - Pete
Thanks!
Pete
RE: Allowable nozzle loads - ANSI/HI 9.6.2-2001 - what pumps comply?
What are some of the nozzle loads given or how do they specify the loads?
PUMPDESIGNER
For a 6x8-13, at the suction flange, allowable axial force = 3500 lb, allowable vertical tangential force = 3180 lb, allowable horizontal tangential force = 2000 lb
Thanks!
Pete
Thanks!
Pete
Naresuan University
Phitsanulok
Thailand
