Zone Damper & Bypass Damper for 3,500+ CFM
Guys,
Does anyone know of a zone & bypass damper that is capable of handling 3,500+ CFM.  Trane VADA's only are capable of of providing up to 2,500 CFM.  Also, it needs to be capable of communicating w/ a packaged gas/elec. Trane RTU...any input?
RE: Zone Damper & Bypass Damper for 3,500+ CFM
Use two Trane VADA dampers or get an appropriately sized motorized damper to do the same job.  The same actuator can be used to communicate with the packaged unit.
