Aluminum Pulleys - Durability??
Does anybody have any experience with Aluminum Pulleys? I am trying to replace some existing steel pulleys with aluminum ones. They are used on a military vehicle where reduced weight is critical. They drive a large alternator and requires a 12 rib K-Section automotive style belt drive. I am leaning towards a 6061-T6 Aluminum with a hardcoat anodizing. My biggest fear is the wear rate compared to the steel pulleys. I wouldn't have a problem with having them replaced due to wear every 5 years but not once a year - if you know what I mean. Cost is not as big a factor as weight. Any comments or suggestions, good articlas or web pages???
RE: Aluminum Pulleys - Durability??
Cheers
SACEM1
