Furfural condenser
Furfural condenser
Furfural condenser
divice: dry furfural condenser
application: lubricant manufacture
objective: exchange heat between two different circuit of furfural in order to save energy.
subject: Materials Selection
Hi Guys,
is it possible to use carbon steel or stainless steel in tubes of  Furfural condensers?
Tin= 450 ºF  Pin=80 psi
Tout= 400 ºF Pout= 45 psi
have you ever seen this in the manufacturing of lubricant?
I belive that the tubes must be made of aluminum
does any body know why?
Thanks.
RE: Furfural condenser
furfural is a highly reactive alcohol and may be sensitive to metal catalysts. Try the chemical guys.
