Measure dimensions switch between inch and metric.
Why would I be seeing the measure command give me dimensions in inch when the default's are set to mm. The part was created in metric, this happens about 33% of the time when anyone in my group uses the measure command. All sketch dimensions are metric.
Confused.
TAP
Confused.
TAP
RE: Measure dimensions switch between inch and metric.
You might also check the settings in your template files.
http://www.EsoxRepublic.com
