Element contact
Element contact
Dear all,
Does any body know how I can use the element contact instead of surface contact. Who knows the tube to tube contact.
saeed
saeed
RE: Element contact
You'll have to be more specific. The contact procedures in ABAQUS check for contact between elements, although surfaces are used to specify the elements faces in question, e.g.
*ELGEN, ELSET=ECONTSURF1
** etc
*SURFACE, TYPE=ELEMENT, NAME=SCONT1
ECONTSURF1 , S1
** etc
What exactly do you want to do?
MRG
http://www.analysis.demon.co.uk
RE: Element contact
Thank you for your kind attention.
My model is coaxial two cylinder with different mechanical properties that fixed in one end and applied tensile load in another end (because of symmetry I run a quarter of this model). In this model I have some problems with surface contact and element contact may help me.
saeed
