Watertube vs. Firetube Pros Cons
I realize that this thread is general, however:
As a hobby I am getting into steam engines, and wanted to know the design considerations that would determine if you would use a watertube or firetube boiler and furnace system as well as what the pros and cons of each are.  Thank you for all your help!
RE: Watertube vs. Firetube Pros Cons
Supa:
In the true, engineering sense there is no pro or con (or competition) between the water tube boiler design and the fire tube boiler design.  Each fits an application or niche that the engineer specifies or identifies.  In the general scheme of things you would never apply a fire tube design (“Scotch Marine”) to a high pressure steam requirement.  The reason?  Very simply, the cost of applying a high pressure to a large diameter vessel goes up because the thickness of the vessel wall goes up – as well as the tube sheets and the involved welding.  As any engineer will appreciate, the water tube design is “tailored” to high pressures because of the nature of the smaller diameter tubes being more accommodating to withstanding the high pressures with less wall thickness.  Additionally, as the capacity needs increase, so does the diameter of the Scotch Marine vessel and the wall thickness requirements really skyrocket when compounded with high pressure steam requirements.  The water tube design is much more flexible because all you have to do is add more tubes for capacity and it adapts very well to superheating and efficiency applications.  It does, however, take relatively more room.
On the other hand, at the relatively small capacities and low pressures (50 – 150 psig) you will find that the cost and compactness of the Scotch Marine design is very acceptable.
The cost (and sometimes the size or “foot print”) of the ultimate solution really determine the design to apply to the application.  That is why Scotch Marine designs find acceptance in commercial and small capacities such as laundries, breweries, dedicated services, etc.
My advice is: don’t try to pit the Scotch Marine against the water tube design.  Each has its niche and does quite well there.
Art Montemayor
Spring, TX
Thanks guys, I got the information I needed!
What type of steam engines are you talking about?
The latest steamers for cars were of the water tube design, small but they worked well. There are small WT and Fire tube boilers on small ones the scotch seems to last longer w/o trouble. say 2 to 75hp, after that WT takes over.
also the pressure scotch can be expensive above 30 hp if the pressure exceedes 350 psi.
ER
