Membrane for Gas/Liquid Separation
I am looking for a membrane which allows the passage of H2 gas while prohibiting the passage of an aqueous liquid solution.
The membrane must allow the passage of approx. 200 sccm of H2 in as small of an area as possible (hopefully less than 10 cm^2) with a pressure drop as small as possible (hopefully less than 1 psi).
Preferably, the material has the potential to be manufactured cheaply in large quantities and will not tear easily, though these are not essential requirements right now. Please let me know if you are aware of any membranes/manufacturers that might work for my application.
