Inspection procedure
We have a tubes manufactured since 3 and 5 years, I want to know wich inspection procedure can we use for inspection of these tubes?
Regards.
Regards.
RE: Inspection procedure
Please be specific. What is the Tube specification and grade? What is the intended service?
From the sketch information provided by you it appears that you are picking up some stock material for your new project.
Does the material have the traceability. Does Certificate and marking co relate. If so then you may resort to check alalysis of Physical and chemical properties (This is for your satisfaction).
If you do not have any back up document that i would resort to PMI to sort the grades and then decide based of the use.
For example if you are going to use it for hand rails in a structurer why bother about the Hydro test.
If your intention is to resell then your approach shall be more severe.
Good Luck
B.Moorthy
moorthykar@yahoo.com
krishn1a
