DATA SHEET
DATA SHEET
Hello
I have to do 100 data sheets with same data (different tag numbers). Is there a way that I do one data sheet then copy it to other 99? Any help will be appreciated.
RE: DATA SHEET
RE: DATA SHEET
what you can do is, make a default of the datasheet and fill it with the necessary data. Then, add this to the profile of the instrument-type. Select all the tags in the index browser for which you want to fill the specs and select generate spec. This way, the tags will get the appropriate specsheet and already filled with the right data.
Good luck.
Wijnand
RE: DATA SHEET
