Dwg View problem
Dwg View problem
Here is a new one for me. I have a top level assy dwg with sever al type of views. Everything has always worked good with it. A couple days ago I renamed the dwg, assy and a couple parts within SW Explorer. Did where used and it renamed no problem. Now when I open the dwg, it looks good but will not save unless it rebuilds. A msg window says: "Views on inactive sheets need updating. If they are not updated, these views will appear empty when the drawing is opened in the SolidWorks Viewer or in View Only mode. Note that the update operation might increase the time required to save the drawing.
Update the drawing?" I click yes, it rebuilds, tells me a part needs to be saved, then saves. Then the main view goes blank. The whol process starts over. My VAR has the files and don't have an answer. Any clues? This dwg is very important to us right now. thanks
RE: Dwg View problem
Jason Capriotti
Smith & Nephew, Inc.
The fix was to go to Tools/Options/System Options/Performance then check the box “Verification on rebuild”.
Everything works well now.
