Mechanical Desktop FTP
I am trying to set up the FTP option in the MDT open menu and it is giving me trouble. I had it working at one point, but it stopped because the server went down. I did not realize the server was down, so in trying to fix the problem, i deleted the ftp location from MDT i had, and re-did it. Now, it will connect to the server (i can see the files and folders and everything else), but it will not let me open any of the files. An error message appears that says "server may not be accessible" It is working though in all of the other programs where I have the FTP site setup. Are there settings somewhere that I can change in MDT, or is there a possibility the server is causing the problem? The server is supposedly setup the same as it was when MDT FTP worked.
