Using Online CAD Libraries?
I have a question regarding downloading non-native Pro/E files:
Is there a trick to getting .igs files to show as complete solids? Often when I am downloading parts off of the Web, the only option is use .igs for a particular file. When I open the part in Pro/E, not all of the geometry is shown as solid - some of it remains wireframe. Very frustrating.
Does anyone have any helpful hints?
btw....I am using Pro/E 2001.
JW
JW
RE: Using Online CAD Libraries?
Thanks for the input.
I did try your suggestions. I haven't had any luck with the "heal geometry" option. I have though, had some luck importing the models as ACIS (*.sat). Pro/E displays some errors however, the models appear to be correct.
Thanks again,
JW
