transmission lines
transmission lines
transmission lines
What causes sparks when one opens an isolator of a line that is not loaded
RE: transmission lines
No energized line is ever truly "not loaded".  There will be line charging currents flowing.  Line length, voltage, line geometry all enter into the picture.  The lower the voltage and the shorter the line the lower the charging current.
The spark in disconnect switches is usually caused for the capacitive trapped charge in the system. To minimize this effect, many disconnect switches are specified with arching horn.
The enclose picture copied from in the net is a good example of the problem described above.
