Default colors of lines
Hi all
Now i met with a (maybe quite easy)problem.I am doing comparations between two generated lines with command "plot".The only problem is that everytime i got two lines with colors blue and green.Sometimes i am suffering to tell the little differences between the two lines.It really takes trouble for my eyes.i failed to find the way to change the default colors of lines in the figure.
has anyone an idea?please help me!
Thanks!
RE: Default colors of lines
The third parameter to the plot-command is the color parameter.
CODE
plot(x,y,'r')  % plot red line
There are a number of predefined colors
r - Red
g - Green
b - Blue
c - Cyan
m - Magenta
y - Yellow
k - Black
w - White
You can also define the color using a RGB-vector with element values between 0 and 1
CODE
plot(x,y,'Color',[0 0 1])  % plot blue line
Change one of the line types. Type 'help plot' and you'll get all the info you need to change color, linetype, etc.
For example:
plot(t, y1, t, y2, 'k:') plots line y1 as blue, continuous (default, since no option selected), whereas line y2 is plotted as a black dotted line due to the 'k:' option.
xnuke
