Extruded curbing vs precast concrete curbing
I'm working on a grading plan of a satellite solid waste transfer station (actually a "drop box" facility). I have two luminaires to be placed within the main driving area. To protect the luminaires from traffic, I'm planning on installing barrier-type curbing. The total length of the curbing is about 20 feet in a roughly elliptical shape.
Would it be cost beneficial using extruded curbing for this? Would I be ahead using precast barrier curbing? I've not used extruded curbing before. Would such a small quantity make it too expensive? I opted against bollards in an effort to provide more protection for the poles.
RE: Extruded curbing vs precast concrete curbing
Best, Tincan
"Come to think of it, there are already a million monkeys typing on a million typewriters, and the Usenet is NOTHING like Shakespeare.
Blair Houghton
Bollards...considering the cost of a bollard vs. a damaged light pole, bollards are looking like a pretty good deal.
It would be challenging (and expensive) to relocate the light pole as it is in the bulls-eye of a circular driving area providing light 360 degrees. It would probably lead to at least one additional luminaire.
Thanks again!
Jersey barriers are overkill, curbing won't do a thing to protect against trucks.
I second Maury on the bollards, and I'd be surprised if the Twp./County doesn't require them for public safety. Cheap too; no special equipment needed to install, laborers can do it all by hand.
The thought on the curbing would be to prevent (or strongly discourage) cars from running up over the curb and striking the luminaire.
But, as I mentioned earlier, I will be including bollards as well now. You're spot-on...bollards are cheap and easy to install during the construction.
Thanks again for the feedback.
